# How Can Embedded Linux and Edge AI Improve Real-Time Fleet Monitoring and Transportation Management?
**URL:** <https://forum.aim-linux.advantech.com/t/how-can-embedded-linux-and-edge-ai-improve-real-time-fleet-monitoring-and-transportation-management/1605>\
**Category:** Software\
**Tags:** ai, edgeai, arm\
**Created:** [November 4, 2026, 6:54am UTC](https://forum.aim-linux.advantech.com/t/how-can-embedded-linux-and-edge-ai-improve-real-time-fleet-monitoring-and-transportation-management/1605 "2026-11-04T06:54:41Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![phill.liu](https://avatars.discourse-cdn.com/v4/letter/p/a8b319/32.png) [@phill.liu](https://forum.aim-linux.advantech.com/u/phill.liu)\
**Post date:** [November 6, 2026, 12:49am UTC](https://forum.aim-linux.advantech.com/t/how-can-embedded-linux-and-edge-ai-improve-real-time-fleet-monitoring-and-transportation-management/1605/2 "2026-11-06T00:49:58Z")
</div>
Hi, thanks for starting this discussion. These are exactly the trade-offs we run into on real deployments, so here are some thoughts on the first three questions:
**1. Which ARM platforms suit real-time transportation applications?**
It mainly depends on the AI workload and power budget:
- **Telematics / gateway (GPS, CAN, 4G/5G, light analytics):** NXP i.MX 8M Plus / i.MX 93 class SoCs offer low power consumption, and the i.MX 8M Plus includes an NPU for small vision models.
- **Multi-camera / driver monitoring:** You’ll need more AI compute, e.g. NXP i.MX 95, Qualcomm QCS6490 / Dragonwing IQ9 series, NVIDIA Jetson Orin, or an Arm platform paired with an AI accelerator module.
- Beyond the SoC, check for **wide-temperature operation, wide-range DC input, CAN bus, GNSS, and any in-vehicle certifications required in your market**. In practice these often matter as much as raw compute.
Hands-on examples: [Edge AI Video Assistant on AOM-2521 (i.MX 95 + Ara240)](https://forum.aim-linux.advantech.com/t/how-to-article-building-an-edge-ai-video-assistant-on-aom-2521-powered-by-nxp-i-mx-95-with-ara240-dnpu/1511) and [Advantech Arm platform + Hailo AI accelerator](https://forum.aim-linux.advantech.com/t/how-to-article-edge-ai-made-efficient-advantechs-arm-based-platform-and-hailos-ai-accelerator-module/458).
**2. Is Embedded Linux a better choice for edge devices?**
For most edge AI gateways, yes. You get broad driver support, container support (Docker/Podman), ROS 2, and mature AI runtimes, and with Yocto you can build a minimal, reproducible image. For hard real-time requirements, Linux is often combined with an RTOS (e.g. on a Cortex-M core or a separate MCU), or a PREEMPT\_RT kernel is used.
See: [Get started with ROS on Yocto](https://forum.aim-linux.advantech.com/t/how-to-article-get-started-with-ros-on-yocto/129)
**3. How to deploy lightweight AI models on constrained hardware?**
- Quantize to INT8
- Use the vendor NPU toolchain (eIQ for NXP, QNN/SNPE for Qualcomm, TensorRT for Jetson) instead of running on the CPU
- Choose edge-friendly models (e.g. YOLO n/s variants, MobileNet)
Step-by-step guides: [Deploy AI/ML models on QCS6490](https://forum.aim-linux.advantech.com/t/how-to-article-optimally-deploy-ai-ml-models-on-the-qualcomm-qcs6490-platform-using-linux/1166) and [Object detection on AOM-2721 with Edge Impulse](https://forum.aim-linux.advantech.com/t/how-to-article-zero-to-edge-build-optimized-object-detection-on-aom-2721-osm-development-kit/1293).
More how-to articles are in our [Knowledge Base](https://forum.aim-linux.advantech.com/c/software-release-update/knowledge-base/18). If you’re working on a specific platform or use case, feel free to share the details. It would be great to compare notes here.
_[View the full topic](https://forum.aim-linux.advantech.com/t/how-can-embedded-linux-and-edge-ai-improve-real-time-fleet-monitoring-and-transportation-management/1605)._
