๐Ÿ“š WEDA Technical Documentation
:books: WEDA Technical Documentation
Everything you need to build on Advantechโ€™s WISE-Edge Developer Architecture.
WEDA unifies cloud-to-edge development for Industrial Edge AI, standardizing across chips and devices into one consistent environment โ€” with centralized control, one-click deployment, and full AI lifecycle management.
:white_check_mark: WEDA Core & WEDA Node architecture explained
:white_check_mark: Device Library setup (Python / .NET)
:white_check_mark: Container-based development workflows
:white_check_mark: API references & quick start guides
Whether youโ€™re just getting started or integrating WEDA into an existing project, the docs cover it all.
:backhand_index_pointing_right: Advantech WISE Learning Hub
