@Jems_Cheng
Thank you for your answer about Stby.
However, I checked the link and could not find a way to operate CAN1/CAN2 on the M7.
On the EPC-R3720 that I currently own, CAN1 works normally from the M7. Why is it working normally even though the Stby signal is not connected? Also, which signal is the Stby signal of CAN1/CAN2 on the EPC-R3720 connected to?
I apologize for asking a similar question, but please tell me how to set up CAN1/CAN2 to work on the EPC-R3720.
I checked the operation with [imx8mp-rsb3720-a1-rpmsg-can2.dtb] that Jems_Cheng provided in his previous answer, but no data was sent from either CAN1 or CAN2.
Could you please publish the circuit diagram for the EPC-R3720?
The “SPDIF_EXT_CLK” has been connected to the “UART1_WAKE#” pin:
The SAI2_MCLK has been connected to the “GPIO_LED” pin:
If so, how should the CAN1/CAN2 Stby signal be set?
On A53 (Linux), both CAN1 and CAN2 are working normally.
What is the setting of the Stby signal in that case?
