[OS Image Release WIV0004] Windows 10 IoT Enterprise V1.3.0 on RSB-3720 with NXP i.MX 8M Plus
What’s new:
  1. Lan0 and Lan1 are available
  2. Native HDMI interface is available
Know issue:
  1. Internal RTC will not work. It will be implemented on the Windows 10 IoT Enterprise BSP by NXP soon.
Detail:
http://ess-wiki.advantech.com.tw/view/IoTGateway/BSP/Linux/OS_Support_List_Windows_On_Arm
How-to Article:
Hi Support Team,
Do you know if the Windows media player is working on this version ?
In the 1.0.0 test report it is marked as failed. but in the different version release note, it doesn’t say if there is any improvement on this…
I have a demo to build showing the Win10 on imx8, the ideal is to show a typical Windows application… I thought of windows media player, but if it is not working, then maybe you have other idea ? is there Edge on it ?
Thanks,
Still Media Player does not work.
Please be noted VLC player (ARM64 version) works well.
Hi @_Yusuke_Kuwabara,
thanks a lot for sharing. Yes, I am afraid that Windows Media Player cannot work, but VLC player works. And playback video by webpage via Ethernet ports can also be an alternative.
Best regards
Eunice
Steps to Install New Media Player
1.Download msixbundle and License1.xml
download link: Releases · microsoft/winget-cli · GitHub
2.Download the VCLibs Desktop framework package
https://aka.ms/Microsoft.VCLibs.arm64.14.00.Desktop.appx
3.Download the Microsoft.UI.Xaml.2.7 by link ““download Package”” is on the right side
NuGet Gallery | Microsoft.UI.Xaml 2.7.0
4.Change Microsoft.UI.Xaml.2.7.nupkg to .zip and Unzip
Install WinGet
  1. Launch PowerShell as Administrator
  2. Add-AppxPackage -Path <path to VCLibs .appx file>
  3. Add-AppxPackage -Path
  4. Add-AppxPackage -Path <path to .msixbundle file>
  5. Add-AppxProvisionedPackage -Online -PackagePath <path to .msixbundle file> -LicensePath
  6. winget install “Windows Media Player”
@_Yusuke_Kuwabara please find instructions on how to install a Windows Media Player on WoA in @Andrew_Chou’s post
You will see a new Media Player option after the installation.
No. I installed VLC media player because Windows Media Player didn’t work correctly.
