Dear Partners,
We’re moving from warm-up to phase-in. The AIR-410 is entering its final ramp toward Mass Production in September/E 2025. Now is the time to line up lighthouse customers, secure forecasts, and prepare channel readiness for a scalable Edge AI platform spanning Vision AI to on-prem LLM services.
Why AIR-410 now
Powered by the latest AMD Ryzen™ 8040 processor (up to 54 W, 39 TOPS AI compute), AIR-410 delivers excellent edge inference performance—and can scale to up to 3,511 TOPS when paired with high-end GPUs such as RTX PRO 6000 Blackwell Max-Q Workstation Edition. A flexible 3-slot expansion enables a broad range of GPUs and add-on PCIe cards, all in a compact, low-noise chassis suited for Medical Imaging, AOI Inspection, and on-prem LLM workloads.
Product Highlights
l Processing & Memory: AMD Ryzen™ 8000 Series (8845HS / 8645HS), up to 96 GB DDR5-5600
l GPU & PCIe Expansion: 1 × PCIe x16 (signal x8) slot; compatible with RTX PRO 6000 Blackwell Max-Q/RTX 6000 Ada / 4500 Ada / 4000 Ada / 5070 / 5060 etc.
Max PCIe card size: W60 × H130 × D305 mm
l Chassis & Power Compact: W240 × H190 × D380.7 mm; built-in 850W Flex PSU; < 38 dBA under typical load (under 52.02 dBA, Full load)
l Rich Connectivity: 3 × 2.5 GbE, 4 × USB 3.2, 4 × COM, HDMI + DP dual display, 2 × 8-bit GPIO (optional)
l Storage & Expansion: 3 × M.2, 2 × 2.5" SSD, 1 × PCIe x16 (signal x8)
l AI Software Toolkits: Edge AI SDK inference kit, SUSI API
