Hi, I have a ROM5722 and a SOM-DB2500.
I am trying to install Windows 10 IoT Enterprise on ARM
following this guide, [How-to Article] Start Using Windows 10 IoT Enterprise Using the Advantech ROM-5722 — An Arm-based SMARC 2.1 Computer-on-Module with NXP i.MX 8M Plus
I can’t get 3.3V on the LVDS connector (LVDS1 Connector)
I have set the jumpers according to SOM-DB2500_User_Manual_Ed.3_FINAL.pdf
From the design doc SOM-DB2500_A101-3_20191007%20.pdf I can see that LVDS VDD has to be enabled by software.
More specifically the ROM5722 needs to assert LCD0_VDD_EN_1.8 from its pin LCD0_VDD_EN
• So how to I enable the LVDS VDD enable signal.
Is this a bootloader / firmware problem ?
Another possibility is to install via HDMI - however
The latest version of Windows 10 IoT Enterprise for ARM64 is V3, more specifically ROM5722A1AIM20WIV0003.
This does not support native HDMI
I can see that you have released V4 (WIV0004) for RSB3720 more specifically RSB3720A1AIM20WIV0004
Which in the release notes states 2.Native HDMI
When will you release Windows 10 V4 for ROM5722 and compatible firmware etc.
