I built an imx-image-full Mickledore image based off the adv-6.1.22-2.0.0.xml manifest.
The image builds successfully and I am able to boot it and use it properly from the SD Card.
I connect to the board using SSH since I do not have the debug cable.
I was trying to flash the image onto the internal eMMC but the system just hangs during the process and doesn’t respond until I reboot it.
In general, this happens whenever I try to do any heavy file operations.
I have tried using a different SD Card but the behavior is the same.
If I use the command memtester with 1M or 10M as parameter, it seems ok.
If I use 1G, for example, it hangs while “trying mlock”.
Could there be an issue with the DDR RAM?
How to diagnose and fixing this?
(I am a beginner using this platform.)
