How to setup LLM inference on AIR-030?
Using Containers to Package AI Applications on Jetson: Solving JetPack Dependency and Deployment Challenges
NVIDIA officially adopted an Ubuntu 22.04-based environment in JetPack 6.x (6.0 / 6.2), corresponding to the L4T 36.x series. This is a major upgrade for developers. However, challenges remain—AI application dependencies are still fragmented across different JetPack minor versions.
How to use Docker container technology to package AI models and applications for fast, stable, and version-agnostic deployment on JetPack 6.0 and 6.2 environments.
Dependency Challenges in JetPack 6.x
JetPack 6.0 vs. 6.2 :
JetPack L4T Ubuntu Kernel Driver/Library
6.0 36.3.0 22.04 CUDA 12.2, TensorRT 8.6
6.2 36.4.3 22.04 CUDA 12.6, TensorRT 10.3
Although both are based on Ubuntu 22.04, there are still differences in GPU drivers, CUDA Toolkit, and TensorRT engine versions between the two, leading to the following issues:
  • A TensorRT engine compiled on JetPack 6.0 may not run correctly on JetPack 6.2
  • The PyTorch GPU version must match specific CUDA and driver versions, making cross-version compatibility error-prone
  • It becomes difficult to maintain consistent deployment of the same inference application across multiple devices
Benefits of Containerization
Decoupling JetPack Dependencies
Using Docker containers to package the AI runtime environment (including CUDA, cuDNN, TensorRT, PyTorch, etc.) allows all dependency versions to be locked inside the container, avoiding constraints from the underlying JetPack version.
The same container can run on both JetPack 6.0 and 6.2.
By using NVIDIA’s official L4T container base image, such as dustynv/pytorch:2.1-r36.2.0, compatibility with L4T 36.2 is ensured. Even when JetPack is upgraded in the future, deployment can continue as long as the GPU driver remains compatible.
How To
Docker Runtime
If you need to use the GPU inside a container (e.g., to make the NVCC compiler and GPU available during the docker build process), it is recommended to set the default Docker runtime to nvidia. This ensures that GPU resources are properly accessible during both the build and runtime phases of the container.
Please follow the steps below:
  1. Install the nvidia-container
sudo apt update
sudo apt install -y nvidia-container curl
curl https://get.docker.com | sh && sudo systemctl --now enable docker
sudo nvidia-ctk runtime configure --runtime=docker
  1. Restart Docker Service and add User in docker group
sudo systemctl restart docker
sudo usermod -aG docker $USER
newgrp docker
  1. Add Docker Configuration
    Create the /etc/docker/daemon.json and add below content:
    "runtimes": {
        "nvidia": {
            "path": "nvidia-container-runtime",
            "runtimeArgs": []
    "default-runtime": "nvidia"
  1. Restart Docker
NVIDIA provides CUDA Containers for Jetson Orin
Install the Jetson-containers
cd $HOME
git clone https://github.com/dusty-nv/jetson-containers
bash jetson-containers/install.sh
GenAI Example:Ollama Infrence
  1. Download Docker Image
docker pull dustynv/ollama:0.6.8-r36.4
  1. Run Container:
jetson-containers run dustynv/ollama:0.6.8-r36.4
  1. Run Ollama with gemma3 Model:
ollama run gemma3
