EPC-R7300 wake on lan
Hello Team,
we are trying to enable wake on lan on the EPC-R7300.
the ethtool shows that the interface is well supporting the “magic packet”
with wireshark we can also see the magic packet arriving.
but when putting the Jetson under deep sleep it can’t wake on lan.
do you have some information to share regarding the WOL on the EPC-R7300 ?
what is working and what is not, the limitation ?
Thanks,
Hi Chih-chung,
Have you enabled the WoL function by the ethtool for the LAN port?
https://wiki.archlinux.org/title/Wake-on-LAN
Hello Jems,
yes it is enabled.
do you know if WoL is working if the device is power off ? or only if it is suspend ?
is there any way to keep the LAN powered when power off ?
Thanks,
Hi Chihchung,
The EPC-R3720 is AT power mode so it cannot support the WoL when device is power off.
