[ Release Note ] Edge AI SDK v3.2.0
QCS6490 AI Suite
AI Software Suite offers breakthrough AI accelerators and Vision processors uniquely designed to accelerate embedded deep learning applications on edge devices.
Qualcomm devices are accompanied by a comprehensive AI SDK that enables the compilation of deep learning models and the implementation of AI applications in production environments. The model build environment seamlessly integrates with common ML frameworks to allow smooth and easy integration in existing development ecosystems. The runtime environment enables integration and deployment in host processors, such as ARM based products, when utilizing QCS6490 vision processor.
SDK
SNPE is a SDK designed to streamline the development and deployment of edge applications demanding high AI performance. This reference application software package empowers users to expedite their time-to-market by minimizing the development workload. SNPE encompasses a user-friendly set of fully operational application examples based on GStreamer, featuring pipeline elements and pre-trained AI tasks. These examples leverage advanced Deep Neural Networks, highlighting Qualcomm’s AI processors’ top-notch throughput and power efficiency. Furthermore, SNPE serves as a demonstration of Qualcomm’s system integration capabilities, showcasing specific use cases on predefined software and hardware platforms. Utilizing SNPE simplifies integration with Qualcomm’s runtime software stack and offers a starting point for users to fine-tune their applications. By demonstrating Qualcomm’s system integration scenarios on both predefined software and hardware platforms, it can be used for evaluations, reference code, and demos. This approach effectively accelerates time to market, streamlines integration with Qualcomm’s runtime software stack, and provides customers with a foundation to fine-tune their applications.
Software Installation files are available at
l Edge_AI_SDK-installer-3.2.0
Are there any installation guide? It was failed on my desk.
root@qcm6490:~# ./Edge_AI_SDK-installer.run
Verifying archive integrity… 100% MD5 checksums are OK. All good.
Uncompressing EdgeAISDK archives 100%
non_root_en file exist
non_ending_msg_en file exist
Are you sure you want to install EdgeAISDK? [Y/n]Y
ADVANTECH Co., Ltd. , END-USER LICENSE AGREEMENT
Please carefully read the following terms and conditions before using this produ
ct. It contains software, this use of which is licensed by ADVANTECH CO, LTD., t
o its customers for their use only as set forth below. If you do not agree to th
e terms and conditions of this agreement, do not use the software. No part of th
is software may be reproduced, copied, translated or transmitted in any form or
by any means without the prior written permission of ADVANTECH CO, LTD..
GRANT OF LICENSE:
ADVANTECH CO, LTD. (the “Licensor”) grants to you this
limited, non-exclusive, non-transferable, non-assignable license
solely to use in a single copy of the Licensed Works on a single product for
use by a single concurrent user only and solely provided that you adhere to
all of the terms and conditions of this Agreement.
ASSENT: By Installing the file package containing this software, you agree that
this Agreement is a legally binding and valid contract, agree to abide by the
intellectual property laws and all of the terms and conditions of this
Agreement, and further agree to take all necessary steps to ensure that the
terms and conditions of this Agreement are not violated by any person or
entity under your control or in your service.
OWNERSHIP OF SOFTWARE:
The Licensor and/or its affiliates or subsidiaries own certain rights that may e
xist from time to time in this or any other jurisdiction, whether foreign or dom
estic, under patent law, copyright law, moral rights law, trade secret law, trad
emark law, unfair competition law or other similar protections, regardless of wh
ether or not such rights or protections are registered or perfected (the “Intell
ectual Property Rights”), in the computer software and hardware, together with a
ny related documentation (including design, systems and user) and other material
s for use in connection with such computer software in this package (collectivel
y, the “Licensed Works”).
RESTRICTIONS:
(a) You are expressly prohibited from copying, modifying, merging, selling,
leasing, redistributing, assigning, or transferring in any matter, Licensed
Works or any portion thereof.
(b) You may take a single copy of materials within the package or otherwise
related to Licensed Works only as required for backup purposes.
(c) You are also expressly prohibited from reverse engineering, decompiling,
translating, disassembling, deciphering, decrypting, or otherwise attempting
to discover the source code of the Licensed Works as the Licensed Works
contain proprietary material of Licensor. You may not otherwise modify,
alter, adapt, port, or merge the Licensed Works.
(d) You may not remove, alter, deface, overprint or otherwise obscure
Licensor patent, trademark, service mark or copyright notices.
(e) You agree that the Licensed Works will not be shipped, transferred or
exported into any other country, or used in any manner prohibited by any
government agency or any export laws, restrictions or regulations.
(f) You may not publish or distribute in any form of electronic or printed
communication the materials within or otherwise related to Licensed Works,
including but not limited to the object code, documentation, help files,
examples, and benchmarks.
TERM:
This Agreement is effective until terminated. You may terminate this
Agreement at any time by uninstalling the Licensed Works and destroying all
copies of the Licensed Works. Upon any termination, you agree to uninstall
the Licensed Works and return or destroy all copies of the Licensed Works, any
accompanying documentation, and all other associated materials.
GOVERNING LAW:
This License Agreement shall be governed by the laws of the China
DISCLAIMER:
In no event shall licensor or its suppliers be liable to you or any third party
for any special, incidental or consequential damages of any kind, or any damages
whatsoever, including, without limitation. Those resulting from loss of use, da
ta or profits, whether or not licensor had been advised of the possibility of su
ch damages, and on any theory of liability, arising out of or in connection with
the use of the licensed works. Some jurisdictions prohibit the exclusion or lim
itation or limitation of liability for consequential or incidental damages, so t
he above limitations may not apply to you. These limitations shall apply notwith
standing any failure of essential purpose of any limited remedy.
SEVERABILITY:
In the event any provision of this License Agreement is found to
be invalid, illegal or unenforceable, the validity, legality and
enforceability of any of the remaining provisions shall not in any way be
affected or impaired and a valid, legal and enforceable provision of similar
intent and economic impact shall be substituted therefore.
ENTIRE AGREEMENT:
This License Agreement sets forth the entire understanding
and agreement between you and ADVANTECH CO, LTD.., supersedes all prior
agreements, whether written or oral, with respect to the Software, and may be
amended only in a writing signed by both parties.
ADVANTECH Co., Ltd.
ADVANTECH Building, No. 1, Alley 20, Lane 26, Rueiguang Road, Neihu District, Ta
ipei 11491, Taiwan, R.O.C.
1, May, 2013
I accept the terms in the License Agreement [y/n]y
copy application file …
Use non-root installation …
func_entry: fail (Linux Type is None)
root@qcm6490:~#
root@qcm6490:~# uname -a
Linux qcm6490 6.6.28-01890-g350dfd604d2f-dirty #1 SMP PREEMPT Wed Jun 19 20:29:11 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
root@qcm6490:~#
Dear [Yusuke_Kuwabara],
Please install it by non-root user
If you have more issue with install Edge AI SDK,
Please feel free send email to us.
Thanks.
Best Regards,
Jackhsuan.liao
It works with aom2721a1_yl01101_k0606028_q6490_08g.
Thanks.
