[SOLVED] Install Linux on EPC-R3720
I have an EPC-R3720 with Windows 10. Is it possible to install Linux on it instead? I found your Yocto images for RSB-3720 but they don’t work on EPC-R3720.
Yes, it can install Yocto Linux on the EPC-R3720. The single board use is the RSB-3720 so it can reference the RSB-3720 user guide to flash Yocto Linux. Please check the RSB-3720 wiki user guide.
RSB-3720 user guide - ESS-WIKI (advantech.com.tw)
Thanks for your reply. I followed these instructions, but when I reboot in eMMC mode, the system doesn’t boot at all. I get the BIOS screen with the menu that says Device Manager, Boot Manager, Boot Maintenance Manager.
Hi ~
Could you successfully to boot the Yocto Linux image from the SD card?
Hi ~
if you can boot Yocto Linux from SD card, please input the command below to disable mmc bootpart for Win10 by “mmc bootpart enable 0 0 /dev/mmcblk2”
That worked! Thank you!
