Terminal console for android os
Is there a Terminal console of Android system?
Hi Kent,
Yes, Android systems do support terminal console access, but it depends on the build type and system configuration.
Typically, there are several ways to access a terminal on Android:
  1. ADB Shell (recommended for development)
    Connect the device to a host PC and use:
    adb shell
    This provides command-line access to the Android system.
  2. UART / Serial Console (if supported by the hardware platform)
    Many embedded platforms expose a UART debug port that allows console access during boot and runtime.
  3. Terminal Applications
    For development builds, third-party terminal apps (for example, Termux) can provide a local shell interface.
For embedded development platforms, ADB shell and UART console are typically the most common methods used for debugging and system access.
Best regards,
Pitchai Muthu M
Embedded IoT Core SW Team Leader | Advantech
