I’m working on updating android on RSB-4810 board. I’ve installed RKDevTool and Driver Assistant packages on my PC (Windows) and I’m able to connect my PC with the board and see my device as Maskrom device in RKDevTool.
“4. Power on the RSB-4810 and press “Ctrl+c” in the debug terminal to stop at u-boot”.
How do I enter the “debug terminal”? Do I need to install some additional software? Will that debug terminal connect to the RSB-4810 board via the same USB cable that RKDevTool is using? Please provide instructions how to achieve this step.
After your last advice I was able to connect the board with my PC using the debug cable. But in order to do so I had to connect pins 2 and 3 on J1, not 1 & 2 as stated in http://ess-wiki.advantech.com.tw/view/RSB-4810_Android12_OS_User_Guide “Short pin 12 and power on the RSB-4810 to enter MASKROM mode. Change back to pin 23 before click “Run” to flash image”
I have an issue with the step 8 of the procedure, where I’m getting the error I’ve described in my previous post. Please advice how I can fix this problem.
Check the screenshot the RKDevTool are not select the correct the image file path.
Please click the latest frame on each image file and select correct files and images.
