Problem Description:
Testing RS 485 with Adam-4520
Answer:
Prepare RS-232 to RS-485 converter (Adam -4520)
COM4(232/485) (ttyS4 , 115200) , CN18 : Pin4 and Pin6 (jumper)
Note : DB9 Pin 1 DATA - and DB9 Pin2 are DATA + -
Hardware setting :
4.Install “ComAssistant V1.1 APK in RSB-4680 (android system) , Execute “AccessPort” tool in x86 (Window system)
5.ComAssistant setting
- AccessPort tool setting
Need to turn on the serial on/off function
Then you will see that the “send” function will turn on
RS485 Testing:
When you key the number in send data window (Android system) , then press the “send” button , the AccessPort tool will receive the data .
